Terry, with your car setting on level concrete use a plumb bob and string to drop lines down to the floor from both of your front spring eye bolts. Then do the same from the axle center lines down to the floor. Using a chalk line snap lines on the floor connecting the two front points and then do the same for the axle center points. Measure the distance between the front lines and rear lines at the wheel well area. These dimensions should be identical which means the rear axle centerline is the same as the spring pocket centerlines. This would confirm that when you redrilled the seats the dimensions matched. If everything matches then depending on your model you can find matching factory punched assembly holes in the frame rail bottoms several inches ahead of the front spring hangers(boxes) which are in the same location from one side to the other. When you find these holes drop your plumb again from the frame holes to the ground on each side of the car and then snap another line on the concrete which is now the third parallel line on the floor. Measure from this line back to the axle center line and see if the dimensions are the same. If they aren't then the spring hanger(box) needs to be loosened and shimmed on one side or the other which will move the axle centerline parallel to the chassis centerline. Hope this helps sorry for the length 75Sport
