8-3/4 w/Yukon axles, fuel cell, leaf springs, aluminum radiator, Weld wheels, MORE!
clinteg
KS
These are some parts that have been taken off my car or were left over.
A-Body 8-3/4 rear with Yukon axles and green bearings with approximately 300 miles. Axle housing has been beefed up with straps welded to the spring perch areas - $600 OBO.
I have brand new spring perches in the box if wanted.
15" Weld wheels with LOW mileage Mickey Thompson 235/50/15 street slicks - $400 (tires alone are $400 new)
(SOLD) Race lug nuts (set of 10) - $20
Landrum rear leaf springs - $180
Leaftspring pinion angle shims - $20
Northern aluminum radiator - $130
(SALE PENDING) 12 Gallon fuel cell - $50
(SALE PENDING) Fuel cell mounting straps - buy the fuel cell and I'll throw them in
Holley fuel pressure regulator - $20
Carter fuel pump (not sure this is working properly or not. would not keep up with holley 950HP) - $30
AFCO heavy duty leaf spring sliders - $100
(SALE PENDING) Rear shock plates - $50
741 center section (lincoln locker needs cleaned up. turns easy) 2.7X gears - $100
Jegs Sport Lite 15X8 Wheel - $50
90 Degree AN fittings (push lock) - $5 each
3/8" NPT to -8AN adapter - make offer
Brass push lock fittings - make offer
Aeroquip 3/8" NPT plugs (1 is spray painted black.) - make offer
(SALE PENDING) Fuel filter (unknown brand w/stainless filter) - $30
What is the diameter and length of the fuel filter and what size inlet/outlet fittings does it have? Also interested in the shock plates.
What would you want for them shipped to 33594?
PM sent
I will get the measurements when I get home later. It was set up on a -8 fuel line with the brass push lock fittings.
interested in separating the axle's from the housing? i have interest in the axle's alone.
If I do not get the entire rear sold, I may consider it. But not interested in separating the axles at the moment.
All other inquiries replied.
Clint
If you can find me someone that wil buy my bike, I'd take that whole rearend off your hands.
Heck I would be interested if the wife wasn't so against them. I had to sell mine. :protest:
Is the carter pump for BB or SB? Do you have the fuel line fittings? 3/8?
Pump came off my small block 340/416. All the fittings shown are what came off of it. And yes I believe it has 3/8" threads. The blue fitting is 3/8" to -8AN.
The following items have been sold.
Lug nuts
12 Gallon fuel cell
Rear shock plates
Fuel filter
Spring perches
What is the width of the rims, and how much back spacing?
I BELIEVE they are 15X8 with 4.5" backspacing from what I can tell. I have never had the tires off so the wheel width I'm guessing on.
All other questions PM'd. Sorry for the late replies.
