It depends on what gears are in them. I figure they must be at least 100lbs
I used my 4.10's, 4.56's and my 5.13's last night to do the rear seat covers
for my Dart. (don't ask!!!). So I know they weigh alot!!!
Well, lets see, when I drag them over, out from under the shelf, freakin heavy. On my back putting it on 1 handed, ouch heavy. Hard as heck to pick up on your back. 2 hands for that.
100 lbs or better i think.
Id say drum to drum its 170-180 lbs. The pumpkin itself is almost 90 lbs, the housings gotta be at least 25 lbs, then you have axles which are another 30-40 lbs or so.Then depending on what brake set up you have theres even more weight.
sic71dart, according to my grunt-o-meter, I think you're calling it pretty close. When I moved mine into the shop last fall, complete with pig, axles, brakes, drums, etc., my grunt-o-meter went off the end of the scale. OUCH!
