That's right, and one of the lower nuts will have a funny washer on it.. pay special attention to how it fits .. that's the axle bearing adjuster, and retainer..
there is a hole in the axle flange to fit a socket into and get the bolts out of the backing plates. Then the axles pull out. You're correct on the adjustment, no significance
