8 bolt flywheel ID?
junkyardhero
Los Angeles
alright trainspotters, who can tell me what this goes to?
there's zero numbers, letters, markings or unique machine work on it.
146 teeth
total width: 13 3/4"
center hole: 2 3/4"
center dished part: 5 3/4"
thickness: 1 1/4"
outer pressure plate bolts 12 5/8"
inner pressure plate bolts 11 5/8"
bolt holes are 1" apart
center to center 1 1/2"
center to center across 4"
it's steel and weighs approx 1 bajillion pounds.
That’s an 11 inch flywheel. Only fits big blocks with the correct bell housing.
Could be steel but I’d have to see the back of it. If it’s cast iron it’s probably OEM.
I don’t remember the aftermarket making cast iron flywheels but they may have.
