8 qt oil pan
rod7515
Red Lion PA
I am going to be putting a 360 block in my 66 Dart. I purchased the oil package from mancini that includes an 8 at oil pan. Was wondering how many others may be using this pan and if you had to alter your k frame in order to clearance the pan. If so could you post pics of the k frame alterations that you did. My Dart was originally a 273 and I have bought the conversion kit from Schumacher the accept the block.
Don't forget your pics!!
Wasn't sure if this should go in small block section or maybe suspension. If it needs moved please do so
Thanks Rodney
