85 Or 100 ft/lbs?
Small Block Mopar Engine
  1. SpeedThrills
    SpeedThrills Well-Known Member
    1,406
    241
    Jun 3, 2008
    Very South Jersey
    Local Time:
    2:59 PM
    Regarding LA360 main cap bolts; I see in several places that the torque should be 85ft/lbs. However, in Larry Shepard's, "How To Hot Rod Small Block Mopar Engine's", he states 100.
    And the truth is...??
  2. jos51700
    jos51700 Well-Known Member
    5,028
    1690
    May 24, 2009
    Bel-Ray
    Local Time:
    1:59 PM
    Depends on bolts (new/used/ARP/Chinese), main caps, lubed or no, etc.
    And you have....______?
    • Agree Agree x 1
    • RustyRatRod
      RustyRatRod 30 Degrees Outta Whack FABO Gold Member
      56,401
      25346
      Jun 7, 2010
      Georgia
      Local Time:
      2:59 PM
      I've seen 105 in some books.
      • Agree Agree x 1
      • krazykuda
        krazykuda Well-Known Member FABO Gold Member How-To Section Editor
        49,827
        14631
        Aug 20, 2007
        Orland Park, IL
        Local Time:
        1:59 PM
        We did ours to 85 ft * lbs like the service manual says...
        • Agree Agree x 2
        • PRH
          PRH Well-Known Member
          1,067
          1599
          Dec 14, 2018
          So. Burlington, Vt
          Local Time:
          2:59 PM
          I do 85 with a drop or two of oil, using stock bolts.
          • Agree Agree x 4
          • Plymouth 65
            Plymouth 65 Floorable Deplorable
            827
            663
            Jun 27, 2016
            Mich
            Local Time:
            2:59 PM
            Unless you've had the block/caps torqued and line bored to a different specification I'd go with the 85 ftlbs defined in the service manual. 65'
            • Agree Agree x 1
            • SpeedThrills
              1,406
              241
              Jun 3, 2008
              Very South Jersey
              Local Time:
              2:59 PM
              I'm reassembling a used engine (new to me). I have no idea what bolts they are. It's wrapped up for the night, I'll look tomorrow.
              Everything has been very good so far. It has KB190's, MP 292 cam, ported 915's w/ 2.02 intakes, Crane gold rockers.
              Everything measured good. I put bearings and rings in it.
              I have to look over the heads (it's been a while since I took it apart), put them on and degree the cam.
              • Like Like x 2
              • SpeedThrills
                1,406
                241
                Jun 3, 2008
                Very South Jersey
                Local Time:
                2:59 PM
                There are six of the regular hex head, and four of the windage tray versions.
                Radial lines would indicate gr 8. I don't know if the circle indicates anything. I have found torque values of 53 (dry), 80, 80 (dry), 90, 100 (lubed), 110 (lubed), 105, 107. All for 1/2-13. Then I stopped looking.
                Are these stock bolts?
              • j par
                j par Well-hung Member
                18,224
                8929
                Jul 2, 2014
                Portland Oregon
                Local Time:
                11:59 AM
                Yes...
              • 318willrun
                318willrun Stomper 4x4... we kept energizer in business
                11,183
                10507
                Sep 13, 2013
                I'm here
                Local Time:
                1:59 PM
                85 lbs and forget it.
                • Agree Agree x 2
                • SpeedThrills
                  1,406
                  241
                  Jun 3, 2008
                  Very South Jersey
                  Local Time:
                  2:59 PM
                  Thanks
                  I agree. Thanks
                  • Like Like x 1
