[SOLD] 85mm BBK Throttle Body
Bakaruda
Texas
Rating - 0%
0   0   0
85MM BBK Throttle
Shipping from Katy, Texas 77493
Price: $175.00+the ride
Payment Methods Accepted: Pay Pal
Large 85mm Throttle Bore
For Use on Crate Engines or Swaps Using a Cable Operated Throttle
Precision CNC Machined Aluminum Casting
Simplify Your HEMI V8 Swap
This BBK Hemi swap throttle body is designed for the popular 5.7, 6.1 or 6.4 liter engine swaps.
These units feature a cable-style throttle linkage to ensure an easy integration to your swap application. OEM Mopar replacement throttle position sensor and idle air control valve are recommended, part numbers listed below. The cable linkage attachment on these throttle bodies are the same as our #1723 throttle body for the 1999-2002 Dodge/Jeep 4.7L engines. A similar cable end will be required, available from aftermarket cable suppliers. BBK does not supply or offer throttle cables.
IAC and TPS Sensor Part Numbers:
Throttle Position Sensor: Mopar# 5017479 AA
Idle Air Control Valve: Mopar# 4861552 AC
85MM BBK Throttle
