[SOLD] 87 D250
niceolddart
S.E. Pa.
Good 3/4 ton work truck. Not pretty, but a good H.D. truck for hauling/towing stuff. Dana 60 limited slip rear (I think it's 4:10 gear, hard to read tag) H.D.4 speed trans. Cab supports good, rockers good, had little rot on frame where axle bump stops were, but patched them with good thick steel, repaired drivers side floor rust & POR 15ed everything. Installed new rubber floor mat, Halogen headlights & adjusters, wiper blades, turn signal switch, truck has newer front brakes & calipers, newer wheel cylinders & rear brakes, new rear brake hose & brake adjuster kits on both sides, 4 good Dunlop radials, etc. This is a good running & driving 2nd owner truck. Original owner took pretty good care of it & was his pride & joy. He is too old to drive any more, so I bought it from him. Again, not a beauty queen, just a good honest work truck so you won't be afraid to scratch it. I am in the 19030 Zip code in S.E. Pa. I will take NO LESS than $2200 for it, otherwise I will keep it for myself. Maybe someone needs a truck like this for local hauling/towing? I will NOT part this truck out. Thanks
It's a 318 2bbl, factory 4 speed manual, no air & I am in Bucks Co. @ 20mi. north of Philly. off of Rt1 & Rt 95 or 295 as it's called now.
Price going back up. Now asking $2600. Installed new rear drums, (12"x3") self adjusters & hardware, brake line from junction block back to rear axle, new flex hose, new lines on axle, has newer wheel cylinders, front calipers & pads, brake line from left to right front wheels. Previous owner did take pretty good car of this truck & used it for what it was made for, WORK. It would make a good scrap hauler for someone.
Very fair. It wont last long. How many miles are on it?
