90 degree adaper install
lilhows340
Ontario Canada
Does anyone know when installing adaper is the plate that the filter used to mate with removed from block?
thanks
Thanks for reply. Just re-read my post pretty vague I'm glad you got it. 90 degree oil filter adapter dah. I had been researching so much I just thought everyone knew what I was thinking lol.
Be sure to use a big copper washer between the bottom of the big bolt head and the top of the adapter, or it will probably leak. I ordered these from McMaster Carr. You need to enlarge the ID of the washer a smidge to get it to go over the bolt.
