90 degree oil filter adapter
bob273
Member
ohio
guys! I just installed new gaskets on the 90 degree adapter. somehow didn't install cork gasket. Put the thin gray one on bolt between and adapter and bolt, started engine ,no leaks, do you need the cork gasket between the block and adapter?, or should I not worry about it.
thanks, bob273
Some engineer put it in there for a reason. I'd say use it. Way cheaper than a rebuild.
