Nov 10, 2007 #1 B baucco Well-Known Member Joined Sep 29, 2007 Messages 190 Reaction score 1 I thought I had the guide for externally adjusting the low reverse and 2nd gears for the 904 but now I can't find it. Maybe I dreamt it,I'm not sure now. Any ideas? Thanks!b.
Nov 10, 2007 #2 73dus Member Joined Feb 17, 2007 Messages 14 Reaction score 2 Location richland pa turn the adjuster in finger tight then back them out 2 turns
Nov 11, 2007 #3 C C130 Chief Mechanical Genius Joined Nov 23, 2005 Messages 3,162 Reaction score 315 Location Boise, ID 72 inch-pounds actually.
Nov 11, 2007 #4 fishy68 Tyr Fryr's Inc. Joined Jan 11, 2005 Messages 16,584 Reaction score 1,284 Location Central, IL (Hooterville) Also note that only the kickdown (2nd gear) band can be adjusted externally. The low/reverse band is inside so you have to drop the panto get to it.
Nov 11, 2007 #5 B baucco Well-Known Member Joined Sep 29, 2007 Messages 190 Reaction score 1 I knew it was something like that but as usual with me,a little knowledge is a dangerous thing! Thanks for the help guys.
