904 adjustment?
baucco
I thought I had the guide for externally adjusting the low reverse and 2nd gears for the 904 but now I can't find it. Maybe I dreamt it,I'm not sure now. Any ideas? Thanks!b.
Also note that only the kickdown (2nd gear) band can be adjusted externally. The low/reverse band is inside so you have to drop the panto get to it.
I knew it was something like that but as usual with me,a little knowledge is a dangerous thing! Thanks for the help guys.
