Rapid Robert
I read an interesting piece on this which said snug both bands (driveshaft wont turn either way) then back off each till the driveshaft will lightly turn (opposite rotation for each band) then loosen another 1/2 turn & lock down the nut. I did this on the band on the side but on the inside band I snugged it (& then some) & the driveshaft will still turn so I just stopped at that point. should I just do the regular procedure (snug (72 in lbs) then back off a number of turns on the inside band or do both in the regular procedure? thank you for your time. RR
