cannucky
The Guy With No Birthday
now your talking my language there Trailbeast thats how I measure stuff too lol
thanks fishy whats the adjustment for a single wrap ? just for the sake of knowing . I'll be using this thread as a reference for any later work or the next time I do one of these .
yeah I wondered the same thing Fishy but then whats the difference between the 66-72 and the 73-up ? since the kit was listed as being for 73 and up I figured this must be one of those little differences .
npt...1/4 or 1/8.....one of those...lol
that is for the tread the screws into the case...
well I fought with the stock lines and got them on and away from the headers , and she's finally back together enough to jack her up and circulate some fluid , I only had 5 qts on hand and the part store is closed Sunday's but the wheels turn backward in reverse and forward in all 3 drive selections, I can't feel it shifting gears when in drive but everything spins smooth no bad vibrations and it definitely clunks going from R to D so I'll just have to get some more fluid and run her down the road a bit and see if she shifts. Next problem is no speedo - probably didn't get the cable all the way into the gear , and that neutral safety switch , is it going to puke fluid when I swap that ? I also can't find the little clip that hols the ball pivot for the kickdown lever but hopefully it will turn up when I pull the car out and clean the garage floor otherwise I'm going to have to search for one of those somewhere .fingers crossed eh!
it's the clip that slides over the vertical rod to connect it to the pivot piece that's bolted to the intake , thanks for the tip Trailbeast , I have to buy a 1" deep well socket to swap the switch and hopefully I'm right about the speedo , the cable kept pushing back into the sleeve when I was trying to screw on the coupler so I think it just didn't push in far enough , at least I hope thats what it is , any tips on get the crossmember hole to line back up I've only got one bolt on each side in and the other two are off by 1/2 the hole , darn unibody.
