Shadow
Got my 70 dart out for a spin and every
gear was first gear. Park still works fine
but put the car in what should be reverse
and it's in first, same with neutral it's all
first gear no matter where you move the
shifter except that park is working fine.
The pointer on the column is working fine
and the linkage below is clean and tight
and as you shift through the gears everything
feels normal other than it is in first gear
Any ideas?
Any ideas?
