904 filter
itsdiz
New Mexico
I have a question for the transmission experts - I thought I knew 904 Torqueflites pretty well, I have owned several slant 6 cars with them and even rebuilt the one on my 1960 Valiant back in the early 1990s. I bought a filter and gasket kit to service mine on my 1965 Barracuda with 273 V8. The new one had two holes - one feed, one return? - and was smaller than the old filter which only had one hole. I looked at the valve body and there is two holes in it so I went ahead and installed the new filter. I was not aware there were two styles, anyone have any information on this?
I just looked up 67 dart automatic and the kits seem to have only one filter that looks like the one pictured, but comes with a ,904 and a 727 gasket.
The image shows both sides of the same filter.
1965 (and earlier) had front and rear pumps. 1966 the rear was done away with.
If you had a dead battery (Pre1966) You could drift start cars with the rear pump.
Mine came with both gaskets also, the filter that was in the trans is like the one in this picture and that is the way I remember them being, but it's been many years since I have had one, could it be just an aftermarket mod for better flow?
My concern about two holes would be if your trans did not have the second inlet it could allow fluid to bypass the filter material.
I don't like those crappy paper filters anyway. I use the brass screen filters. Flows a lot more fluid.
