1. GimmeDanger
    GimmeDanger Active Member
    33
    9
    Feb 17, 2017
    Queens, NY
    Local Time:
    12:29 PM
    Just did a filter and gasket change, there was a coating of material in the pan and a little clump right under the filter, is this acceptable?
    1971, swinger 318. Unknown service history, shows ~60k miles.
  2. Demonracer
    Demonracer 71 Demon 00 Ram 16 Chrysler 300S 05 Caravan FABO Gold Member
    3,059
    1060
    Jan 31, 2010
    Cleveland, Texas
    Local Time:
    11:29 AM
    What color was the old fluid, & did it smelled burnt? If the fluid was still red & didn't smell burnt, I'd say you were good to go. Did you leave the round magnet in the pan to pick up the ferrous metal when the drums wear? If not, I would drop the pan & put one in just to be safe.
  3. GimmeDanger
    33
    9
    Feb 17, 2017
    Queens, NY
    Local Time:
    12:29 PM
  4. GimmeDanger
    33
    9
    Feb 17, 2017
    Queens, NY
    Local Time:
    12:29 PM
    The fluid looked perfectly red and smelled fresh. The rear band was a little bit loose but adjusted easily. There wasn't a magnet in there, maybe one of those little rare earth magnets would be good to stick on the outside? I got a lubelocker gasket so I could drop the pan if I need. It was just enough coating to dull the inside finish and a clump of crap about the size of a quarter. It seems reasonable to me but I'm no expert.
  5. MoparMike1974
    MoparMike1974 FABO Gold Member FABO Gold Member
    2,173
    1508
    Jun 16, 2017
    Maryland
    Local Time:
    12:29 PM
    Yes, a light film and some small particulates is normal. Also, it will tend to collect in the corners so the blob is likely normal too.
    • Agree Agree x 2
    • Demonracer
      3,059
      1060
      Jan 31, 2010
      Cleveland, Texas
      Local Time:
      11:29 AM
      What MoparMike said. The magnet needs to be placed as far from the filter as possible so the ferrous particulates will be pulled away from the filter.
      • Agree Agree x 1
