AJ/FormS
68 Formua-S fastback clone 367/A833/GVod/3.55s
- Joined
- Jan 19, 2014
- Messages
- 25,101
- Reaction score
- 12,451
Directions for installing the shift kit are pretty clear. They will supply all the springs to pump up the pressures, and detail how to adjust the line pressure; it's all in the kit.
But the kit assumes your pump is up to the task in the first place. So do a pressure test now before the tranny comes down. You will be looking for 250ish psiQ@2000rpm, in the L/R servo. In reverse, full pump pressure is sent there.If yo get it, at least your pump is good.
Failing a pressure test, you will have to carefully inspect the pump on disassembly and compare the clearances to the FSM specs
As to the sprag; with your hp level,(525tq/472hp) it might not take much to spin it in the case and then you are back to square one. So in the interest of saving you some disappointment: You might consider a 727 with a bolt in sprag, or
having your 904 professionally built,or
just put on some skinny tires
And for sure NO NEUTRAL DROPS,lol.
Here's a link
Home - A&A Transmissions
Here's a link
