pastortom1
This has probably been covered here before.........
I have a nice 1972 904 behind a mod-318 with a 3.55 posi......I'm just tired of not having another gear for cruising...... I've considered a new tailshaft overdrive, but it just seems too expensive...........
Can someone tell me more about the a-518 I've heard mentioned.....Would it shift with nearly the same ratio's as my 904, with the ADDITION of an overdrive?..........Is it 4 speeds or 5?.............And what, short of a probable driveshaft shortening, would I be up against to swap them?
Will the stock linkage match up? Rear motor mount? Neutral safety switch?
Could you guys walk us through the reality and specifics of the swap? :read2:
