not to hijack, but I also have a mystery leak on my 904....have yet to get under and REALLY look yet but I can see its a little wet looking around my neutral switch,lever shaft,I see its wet on the bottom of the bell and its dripping off my pan.
I installed new front and rear seals,new pan gasket.....not sure where it could be coming from.
also it leaks more when sitting on an upward incline (rear of trans slightly angled downward) than it does the other way around.......and this is just sitting, not running. ( it will leak a good sized puddle in a week or twos time....after sitting all winter it leaked about 2 quarts and soaked my garage floor)with it leaking more at that incline it makes me believe front pump seal would not be the cause being that the fluid it towards the rear of the trans.
Ill be watching the thread to see who has what opinions on common places these 904's leak from. And good luck on getting yours sealed up too!
