904 transmission gear selector grommet-bushing?
TF360
Florida
Ok, where the auto trans. shift lever is there is a round hole- Some type of grommet goes in there. Whats it called? Where can you get one?
I think you're referring to the "shift selector seal".
Here's a thread on it.
904 shift selector seal
You should be able to get one through Advance Auto parts, but if you want to be sure you get the correct one, A&A transmission can help. Bad thing is their shipping costs are high.
No thanks 66. Just the lever where it changes gears from (DR321)-linkage grommet
Column 74 Duster automatic 225. That thread showed it where the Trans control lever meets the rear rod. Grommet in there
