So I'm stumped. I bought an assembled 904 from CRT and it was working great when I finished the car last fall and got the B&M ratchet shifter dialed in. I put about 200 miles on it and had to put it away for the winter. I ended up swapping out the k-member for a QA1 unit. This is only relevant because I had to replace the headers with TTI's to get everything to fit so I ripped everything out to make that install smoother to include my shifter cable.
Now I can't get the transmission to shift into second at all. I figured it was the ratchet shifter not working correctly and after adjusting it more times than I care to count, I'm not so sure that's the issue. It snaps into every other gear without any issues and I can drive the car just fine as long as I skip second and put it in 3rd. Instead of getting second the car goes into what feels like neutral with a little bit of engagement sometimes. If I drive like a grandma around the block I see the rpms drop when I shift 1 > 2. I'm not sure if it fully engages or not but going from 3 > 2 seems to give me nothing everytime.
I started out by adding 2 quarts since it was low due to a small leak coming from my bellhousing once the car is parked. I'm thinking the front seal might be damaged or it may be the vent since I did put close to 11 quarts in it initially before my Lokar dipstick showed any fluid on it. Not sure if that is relevant at all but I figured it's worth mentioning. It's still leaking but it only leaves a small puddle in the garage under the bellhousing after I get it hot. I did move my transmission cooler lines as well and put a sleeve on them but they're braided nylon lines so I don't think they're kinked at all.
Like I said I'm stumped. Seems weird that the ratchet shifter would only have an issue with a single gear and work perfectly everywhere else but it also makes no sense that the trans would stop working for no good reason. The obvious answer is to take it to trans shop but only one place in the area is willing to touch it and they have "at least" a one month waiting list. So help me out here FABO family, I'd rather not see my car sit in the garage and the shop through half the summer after working so hard on it for the last 4 years.
I reached out to CRT already and I'm waiting to hear what they say but I'm always interested in hearing from everyone here. The only progress I've made is checking the nut on the front band adjuster to make sure it didn't come loose. I may just drop the transmission myself to make it easier to work on and probably eventually take it to someone that knows what they're doing.
