[SOLD] 90degree small block oil filter adapter
Nitro67
Painesville,Ohio
Good 90 degree oil filter adapter $100 in Ohio for small blocks
Can you please post a picture of the bolt on its own so I can see what style bolt it is? Meaning are the oil holes in a row or staggered. Thanks Steve
I can after work today
What’s the part number? That looks like a 340 one where is angled a bit more….the 273 one is different, that one is a true 90°
Thanks for the picture. I am looking for a staggered or oval hole style for better torque strength. As seen in the pictures below. They are getting harder to find.
#Oldmanmopar , easy fix, mine started to twist so i welded up two opposite holes and drill new ones a little higher or lower. I think i actually drilled two smaller holes per side.
