95 318 flywheel question
chryslerfat
Monroe,Michigan
I have a 130 tooth flywheel for a cast crank will it work on a 1995 318 magnum. I am using a carb and ditching the electronic`s. I plan to use a LA bellhousing and 4 speed overdrive trans. and do not want issues. Thanks
