cudaspaz
I guess replacing the obviously cracked front bearing retainer did not fix my leak, or may have just fixed one of two leaks.
I have not pulled the trans back out yet, but the only thing I noticed was my input shaft was worn a bit where the front bearing retainer radial oil seal rubs there.
It was not smooth across the shaft and dipped down where the seal makes contact.
Wow, amazing that rubber friction can do that to steel, and I guess the new seal did not make any difference.
Anyways, I am suspecting this is my leak.
Is there a sleeve to repair this?
