[Found!] A Body 8 3/4 Small Bolt Axle Shaft
Hello !! I am looking for only 1 SMALL Bolt pattern 5 on 4 in. Axle Shaft ... I damaged one getting off the bearing race :( ... I am in Madison WI.
How bad did you damage it? If you just "nicked" the area where the bearing is pressed on and it's not a high powered race car, blend the damage with a fine round (jeweler's) file and finish it with some 500 wet or dry. Install the bearing and go!
Norm
