[WANTED] A body drive shaft
According to my 69 FSM, the length for a 340 or 383 with a 727 and 8.75 axle is 47.81 inches long - center of u joint to center of u joint and would be 3.25 inches in diameter. I've got at least 15 different driveshafts and will see if any fit those dimensions.
I took a look at my driveshafts and the closest ones are 45 and 50 inches in length U Joint to U Joint. Good luck with the search.
