A Body fan shroud
craigb
Active Member
Minnesota
I have a 71 Dart 340 with a 26" radiator. All the reproduction fan shrouds I find for 71 A body are for 22" radiator. Any body know if the Mopar Performance shroud for 26" radiator made for B&E body will work?
The 26" radiators for the A-Body cars started in 73. It would help if you'd post your radiator #
The factory shroud for the later model 26 inch a-body radiator is a lot more common that the earlier 22 inch shrouds. I think that's why the 26 inch shroud hasn't been repopped yet.
Checked radiator number today, it's from 68 Charger. Who would have guessed!!!
I have a 1967 Dart with a 26 inch radiator and 360. I got a shroud from Bob Mazollini. Fit great on my Champion radiator using viscous fan and jag clutch. He had two types in stock. Mine is outlet drivers side inlet passenger. Can't remember the other one. They are factory shrouds.
Cheers !
