[WANTED] A-Body front Frame Rail
WARFARE
British Columbia
Rating - 0%
0   0   0
I am looking for a RH(passengers) front frame rail to fit a 69 Barracuda. Upper control arm mount needs replacing. Please let me know if you can help. Thank you.
Patrick
Thanks, that might work though. I can have it shipped to my box address in Washington and pic up after all this Pandemic stuff is sorted out.
What do you want for it?
I found a pic I took of it last month. It does not have the shock mount upright on it so it is just the entire lower frame rail. I do have another one still on a 67 Barracuda but it is missing the bump stop for the upper control arm which is on this rail with the rubber still on it.
Unfortunately I need the rail with the shock mount as it's the part that's corroded. Let me know if you pull off the rail from the 67. I can live without the bump stop.
