A body looking
Lite duster
New Member
Oklahoma
Hello,new to the a body site.i have a 69 super bee and am thinking about buying a car i can race a little bit.wanted to ask some of you a body experts about a car I'm looking at and get your opinions.this is a 76 dodge dart lite.slant 6 is gone now has a 360 with 833 4 speed.motor was bored .30 over.arp rods bolts,high volume oil pump,milodon oil pan,windage trqy,202 heads,stainless steel valves ported and polished heads,comp cam,roller rockers.mopar M1 intake.kb pistons.mp chrome box 750 holly dp.ss rear springs.202 heads ported and polished,comp cam roller rockers,2 1/2 exhaust.holly dp.np air or power steering bench seat.disc front.comes with rally wheels and a set of painted wheels with 10" slicks for rear.new plum crazy paint.also has 8 3/4 rear Posi 391 gears.whats your thoughts on value?wll drive it in a few days.but as usual pics look good.great paint job
Looks great, engine sounds good......My only question would be, is the 4spd a standard ratio or a overdrive?
I suggest this, have the owner drive while you video tape from the rear. Make sure he hammers it through at least three gears. Look at the video, check for SMOKE!! If that looks good and things are tight no more than $10,000 (1976) if 1973 back then it would be more. BTW its a nice looking car.
Thank you all for opinions.still thinking.with this set up what.will 70 mph look like?not I'm hiway much
With this set up how would hiway driving be.70 just one i a while so not to worried but is it drivable on hiway?
Once in a while....you can live with it....once in a while :smile:. 3k plus r's will wear on you though at some point. Really depends on how much highway? That does look like a really nice car though for some fun local street use. :thumrigh:
It would be worth alot more if it was a numbers matching resto with the slannt. Jk!:D
Honestly i can't tell you much about the 3.91's but I can say my slant has 3.55's and it sounds like a pissed off weed eater at 70mph with 25" tires. Its sounds better though than the rear with 2.76's and screwed up bearings did. Your 3.91's will be bearable once in awhile.
