A Body pistol grip
carcarzey
Active Member
Hello. I have a 70 dart swinger with bucket seats. Which pistol grip shifter works for that application. Thanks Ken
I have an E-body pistle grip in my 71' Duster with buckets. The onylmodification that I had to do was make a new mounting bracket that held the shifter on more of an angle. Otherwise my knuckles would hit the dash in 1st or 3rd. Shorter the shifter, the more precise its going to feel going through the gears.
Here,s a pic of mine(B-body one)it has real cherrywood in the handle.I had to drill another hole in it to fit in my 73 Dart Sport 340 4 speed shifter holder.
You need a '71-'74 B-Body shifter. I don't have one in a car but I've seen it.
Specifically the 71-74 B body BENCH seat shifter .
What I had in my Dart, and will again.
I took a "v" cut in the shifter handle below the boot and pulled it back a few inches and then welded up.
Works perfect and you can't see the weld under the boot.
I have a 69 dart my pistol grip shifter is the 71-74 non console shifter it does not hit the dash or anything. I didn't make any adjustments to either the shifter or the handle.
Call Jason at pistolgrip727 .com and he will get you set up
Hope this helps
