A body Power Steering "self turns"
Suspension, Steering and Chassis
  1. daddanjer
    daddanjer Member
    19
    0
    Oct 14, 2007
    Local Time:
    10:05 PM
    Hello everyone , I recently installed a new power steering gear box in our 1966 Dart. I rebuilt steering column , drained and cleaned pump. When I started car I rotated steering all the way right to left at least 8 times. I held slightly at end of turn to put a bit of pressure on system to bleed. Turned off car. Restarted car and gearbox turns by itself to left. I rotated again thinking I did not cycle system to get all air out. Still when running gearbox turns wheels to the left. They will go all the way to stop. I am figuring a defective steering box but thought I would ask if anyone knows of an in-car adjustment that can be made. On some older model GM cars there is a 7/16 nut under a cover on gearbox you can access. You turn nut slightly either way to take the "self turning" out of box. Thought I would ask the best before I pull gearbox back off. Thanks all for your time and help. Ed
  2. BigBlockMopar
    BigBlockMopar BigBlockMember
    1,564
    516
    May 1, 2011
    Netherlands
    Local Time:
    7:05 AM
    You need to fine-tune the 'block' where the high pressure hose enters the steeringbox.
    It listens very closely so just loosen the bolts slightly, and lightly tap the block up or down.
    Also shown and explained here:
    • Agree Agree x 3
    • Like Like x 2
    • daddanjer
      daddanjer Member
      19
      0
      Oct 14, 2007
      Local Time:
      10:05 PM
      Hi BigBlockMopar , WOW!!! Best explanation ever! Thank you so much for your help. Looking forward to the nice tight steering on our Dart! Thanks again... Ed
    • daddanjer
      daddanjer Member
      19
      0
      Oct 14, 2007
      Local Time:
      10:05 PM
      Hello everyone , just an update. I went out and performed adjustment sent by BigBlockMopar and it worked first try. Cant thank BBM enough but from my heart thank you. We do not have much in finances or experience. This site makes people like yourself available to people who are trying to learn and keep these fantastic vehicles on the road. I can express the thanks and appreciation to you all and this site. You have help my son and I on occasion when no answers could be found. Thank you all. Ed
    • BigBlockMopar
      1,564
      516
      May 1, 2011
      Netherlands
      Local Time:
      7:05 AM
      Thanks for reporting back and glad it worked out alright.
    • G50
      G50 Tetanus
      35
      10
      Sep 10, 2016
      Texas
      Local Time:
      12:05 AM
      BigBlockMoper! You nailed that one down. I had rebuilt my steering box in my project car "Tetanus", almost a year ago. Working on getting the 5.7 to fire up and I decided to put the cordless drill on the PS . It made a hard RH turn. Bumped the high pressure block down about 3/16" and she centered right on target. Thanks for the memory stimulation :)
      G50
    • BigBlockMopar
      1,564
      516
      May 1, 2011
      Netherlands
      Local Time:
      7:05 AM
      Good to hear!
