A few checks before college
1970Dart198
Greenwich
I go to The Citadel, in Charleston, SC.
In a few days I will be driving down from Connecticut to attend my next school year.
I was wondering about a few things that I regretfully should have checked when the radiator and other stuff was out of the engine bay.
The Timing Chain and the Mechanical Fuel Pump are my biggest concern. I drive the car normally, maybe a few spurts of speed to see what the 198's got (not a whole lot!) But all together I regularly change the fluids and filters, and I go easy on the car.
Earlier this summer I added a Brake booster and front discs to the Dart for an excellent stopping speed versus no-power drums earlier in the year.
So any other recommended checks I should make before I make the more than 800 mile road-trip to South Carolina?
Thanks in advance!
When was the last time your gear oil in the rear end was changed? Transmission last serviced? Points look clean, not pitted and proper gap? Tires in good shape?
I would also check the u-joints in the drive shaft to make sure there is no play and put together a tool box if u have not all ready just in case u break down along the way.
These guys got it. I'd also pack a few lil spare parts just incase.
I also for got to say also check ur ball joints in the front end and axle Barings
Timing chain slop can be easily checked without removing the front cover. Turn the engine over by hand while watching the distributor rotor. Then reverse and see how far before the rotor follows. Of course, use the degree mark on the crank damper to measure. Anything over 10 deg is cause for worry, though it could probably run for another 100K fine. Slop also makes the timing light mark jump around.
Wheel bearings would be #1 since that can disable you (did me). Suspension and steering slop won't usually stop you, nor the U-joints. I found a totally rusted out U-joint in my Dart and found that was what made the clunk when I shifted from P to R the last 100K miles. Got so bad I felt a vibration ~55 mph, but still drove 400 miles home.
Of course, electrical is the main disabler. Carry spare ignition parts (points, ECU, ballast, ...), alligator jumper wires, a wiring diagram, multimeter. I have a Battery Brain in all my cars, plus wired mine so I get a buzzer if the headlights are on with ignition off. Mini-starters are so light you could carry one in the trunk. I even carry a small carb and electric fuel pump in case my fancy EFI dies. When I change hoses and belts, I keep the old ones in the trunk under the spare tire. This is in all my cars, and they have come in useful. In my 96, I carry a complete timing belt kit since I waited a week for parts once. Similarly, in my 02 I have a spare p.s. pump plastic pulley since getting one wasted a whole day once. New cars will disable you quicker. If anything on the serpentine belt fails, you are down. Parts for new cars can be harder to get than my old Mopars, in my experience, and can cost $$$.
