A leaf hanger problem and solution.
TrailBeast
AKA Mopars4us on Youtube
Arizona
Some may remember this issue with my leaf spring hangers.
In my normal daily driving I do a ton of cornering and it took a toll on the spring shackles.
It cost less than 20 bucks to build two sets of tougher ones.
1/4 thick and 1.5 inch wide plate steel, 1/2 grade 5 bolts and nylon lock nuts.
The poly bushings have a 1.5 inch shoulder so these new shackles fit those perfectly.
When I make a change I don’t post it until it’s tested for months to be safe and effective, so here it is.
The destroyed hangers and the new ones.
Very nice. I ASSume you used a regular bolt with a hex head on the other side? I always thought that splined, small head pressed in boosheet was chinsey and cheap. You proved it.
Nice job on the shackles too.
Yes, it’s a standard grade 5 bolt.
I made a set that I cut the head off and welded the shank into the plate because I moved the hanger brackets inboard front and back for tire clearance.
Then when I saw I had the clearance for the bolt head I made this new set.
You might notice the hanger brackets need to be removed if these ever need to be serviced.
I don’t mind that, as it’s easy enough to do.
I made a 2 inch longer than stock set as well, because I wanted 1 more inch of lift in the back.
These are on the car now.
I am going to get a center drilled aluminum block where the center bolt goes through and then that bolt can be tightened down against that stabilizing the heck out of them.
The only thing I wouldda done different.....because I'm just anal retentive like that is gone with grade 8 bolts. But still, nice work!
