A230 transmission seals
72Ruster
Cali
Hello all, tried searching on here but haven't found any good place to get seals and things for my a230 3 speed. Does anyone know if the shifter arm o-rings from the a-833 are the same size? (78 in photo)
Mine are leaking pretty good, as well as the side cover and the rear is dripping every once in a while. Id probably just have to use some gasket maker for the side.
On another note, is there anywhere that lists the Chrysler part numbers so I can try to find replacements? Thanks in advance.
Autozones website. Just plug in transmission seal. For your year make and model. I think it was on page 2 so don't miss that. Looks like it also fits 904/727 shift shaft and may also be a sector shaft seal for the steering gear.
