A230 transmission
l6hmus
Estonia
Hi,
I'm doing a slant 6 A-904 automatic swap to a V8 (318) for my 69 Valiant.
For that I bought a 318 and a A230 gearbox that came from a 73 Roadrunner.
Is it true that the A230 from an e-body does not fit my Valiant ?
Also, if I don't find a correct tail housing for my a-body then will the 318 and a833 match?
Do I need a v8 bellhousing or are the slant6 and v8 bellhousing same for a833?
Are there differences between the A833 from different Mopars?
Also does a 64 clutch pedal assemble fit to my 69 Valiant ?
Kristjan.
The bellhousing and clutch fork I have on my a230, will it fit a a833 ?
Hi,
Kristjan.
a B/E body trans has the long tailshaft ....it wont work in an A-body without heavy modification and the shifter will be all wrong ....its easier to find a short shaft A-body unit
the V8 bell will accept a 230 or 833 ....a slanty bell will only take a 230 unless its for an OD with the large bearing retainer
64 pedals will not work in a 69 ....completely different setup
Thank you for the reply.
At this moment I have found a 4 speed a833 for sale near me.
Do you know will the clutch, pressure plate, clutch fork and flywheel from a230 fit to a833 or to I have to find different setup for a833.
I have all of the stuff from a230.
kristjan
