WBB
New Member
Have '89 Dodge Dakota with 3.9L, 42RH trans, 200k miles. Transmission failed at highway speed and will not engage in any gear. Atf level is the same with engine off or running. Pressure test revealed no pressure. Dropped pan, atf was very dark with heavy grey jelly/sludge on magnet (very fine particles). Flushed trans, new atf, filter but no change. There is a slight noise coming from bellhousing. Wondering if this problem can be fixed economically or truck is done. Has anyone heard of pump failing so suddenly? Or could be simple like pump bushing? Any thoughts appreciated. Thanks.
