rustytoolss
Does it matter what year overdrive you buy for a swap. As far as the electrical needs to make them work ? Are there better year transmissions to look for ? That will make life easier.
Thanks.the RE version is controlled by a computer....you dont want that one...you want the RH version...hydraulic control governor...had 3 pin plug on it...
What you are looking for is a 46RH which is based on the 727 or the 42RH which is based on the 904.
Thanks.
The RE version started showing up around 1996.
Do you know if the a500's from a V6 , are as strong as if they came from a V8 ?
Are the a500's from a V6, as strong as the a500's from a V8 ?
Anybody have some drivers side pix of a 42RH they can share? I am wanting to look at it and see if i can adapt my stock factory 3 speed floor shift linkage to it.
Nope, they all require the same cutting. Some of the weakening of the crossmember can be offset with subframe connectors and torsion boxes. But you want to do that anyhow.
