indirect_connection
Picked up an A500 trans out of a 89 Dakota. Plan on building it and replacing the 904 currently in my 68 Dart. The existing combo includes a 5.9 Magnum from a Dakota, with Edelbrock heads and a mild cam (like 213/219 @.050). Currently connected through the upgraded stock 904, to a Ford 8.8 axle. I picked up a Holley trans tunnel brace to facilitate regaining some of the strength lost when the crossmember is cut.
I know that the earlier trans aren't as good as the later ones, but it's what I could find and the price was right. Current plans include:
1) Replacing clutches and seals. Plan on using Red Alto clutches and 2nd band. Any real reason to upgrade the reverse band? I figure I won't be romping on it going backwards... Also, I've heard I need to use thinner clutches in the Direct drum. Are the thinner clutches the ones used in the Forward clutch?
2) I think the overdrive unit is know to be week. The 5.9 Magnum came with a toasted 46re. I think I can use the overdrive unit out of it. Let me know if I'm wrong.
3) Shift kit. I've installed a few before, the SHIFT TF-TC, and the basic Trans-go shift improvement kit. Should I go for the TF2 kit for this build?
4) Some sort of mild stall converter. Haven't looked into it much yet. Needs to have a lock-up clutch, so I'm sure there will be less options that for a 904/727.
Anything else I need to upgrade? Any other parts from the 46re work on the a500?
Just a little dirty! As bad is it looks on the outside, the fluid was still red and no chunks of metal in the pan.
Cleaned up a500 on the right, smoked 46re on the right.
