a833 aluminum case Passon Performance
Manual Transmission & Clutch Discussions
  1. rrvolare
    rrvolare 19Swinger69
    1,777
    106
    Jan 25, 2010
    Michigan
    Local Time:
    6:22 PM
    Thinking about changing to 727 auto ... I paid big money for this trans to be built ... do you think i could get what i have in it ? or should i keep it for another project..
  2. 340doc
    340doc Well-Known Member
    2,692
    948
    May 8, 2010
    Hollywood Fl
    Local Time:
    6:22 PM
    5 spd?
  3. brian6pac
    brian6pac Well-Known Member
    4,797
    3244
    Nov 15, 2016
    N.E.Ohio
    Local Time:
    6:22 PM
    Is it a overdrive 4 speed, hemi input shaft ?
    • Like Like x 1
    • rrvolare
      1,777
      106
      Jan 25, 2010
      Michigan
      Local Time:
      6:22 PM
      4 speed slick shift nos case and tail stock 18 spline best of everything in it
      • Like Like x 1
      • mbaird
        mbaird mbaird
        6,132
        3003
        Dec 10, 2005
        boise, Id
        Local Time:
        4:22 PM
        Just curious but what are the ratios ?
      • rrvolare
        1,777
        106
        Jan 25, 2010
        Michigan
        Local Time:
        6:22 PM
        factory ratios
      • rumblefish360
        rumblefish360 So close, yet so far away FABO Gold Member
        38,789
        10383
        Jun 21, 2005
        New York, on a Island
        Local Time:
        6:22 PM
        In a word, no, but! You should be able to get a good return on it considering it is custom built with the best parts you had put into it. How long you have had it, miles on it, drag runs can curve the price a little.
      • rrvolare
        1,777
        106
        Jan 25, 2010
        Michigan
        Local Time:
        6:22 PM
        never been in the car still in box
      • mopardude318
        mopardude318 Well-Known Member
        9,679
        829
        Jan 7, 2005
        Gilroy, Ca
        Local Time:
        3:22 PM
        is the tail housing and side cover aluminum too? about how much less does it weigh from an iron unit?
        I dunno, I sure like 4 speeds...I would keep it, that's one of those parts that once you have it, it'll be hard and expensive to get it back...
      • mbaird
        mbaird mbaird
        6,132
        3003
        Dec 10, 2005
        boise, Id
        Local Time:
        4:22 PM
        Without knowing how much you paid for it we cant advise.
      • rumblefish360
        38,789
        10383
        Jun 21, 2005
        Local Time:
        6:22 PM
        Brand newly professional 1st class work redone never out of the box? Sheeeeeeeeeeeeet.....
        What else do you have that goes with it?
      • rrvolare
        1,777
        106
        Jan 25, 2010
        Michigan
        Local Time:
        6:22 PM
        all aluminum
      • rrvolare
        1,777
        106
        Jan 25, 2010
        Michigan
        Local Time:
        6:22 PM
        new never installed
