[Found!] A833 Input shaft & Bearing Collar
CL3406
BC
I'm looking for a 23 spline, 25 tooth, 11" input shaft in good shape. Also I need the bearing collar, 4.35" in diameter (fits over 307 bearing), 4.28" high. The A833 is 73 vintage. Picture attached for reference.
Might have to have your imput shaft repaired. I just had an imput bearing surface spray welded and machined. Try this link, he's in Vancouver., and very knowledgeable. Cheers. www.gearstogo.com
Thanks for the info...Mine is past repair but I will check this guy out.
