cecil4speed
Hi guys. Installing an OD in my Dart. All going well until I tried to install driveshaft. No way would it go in the transmission. Finally knocked off the rear seal and found a bushing in the tailshaft housing the same OD and ID as my slip tube. Do I have to get a smaller OD slip to fit the inside of this bushing or can I remove the bushing. Probably not because of aluminum tailshaft housing. In all my reading and research on these transmissions, no where did I read about having to change the driveshaft slip tube. Guess I won't finish this today. Thanks for any help, Keith.
