[FOR TRADE] a904 automatic setup trade for 3 or 4 speed setup
Dustert73
Stripping bolts since ‘10
Ohio
I have a small block a904 automatic transmission setup from a 1973 Plymouth duster with around 70,000 miles on it. Comes with transmission, stock converter, flex plate, dust shield, engine to transmission bracing bars, cross member, driveshaft, column shifter linkage, 2 bbl kick down linkage, and reverse light connector. Brand new uninstalled parts include lokar kickdown cable kit, filter, gasket, and 13 quarts of Jegs quick shift atf. Also will add in the remaining parts from my other ad http://www.forabodiesonly.com/mopar/showthread.php?p=1970695326#post1970695326, and cash if nice condition.
Looking to trade for a complete small block A-body 3 or 4 speed setup, (everything needed to swap in a manual transmission to a automatic duster).
Located in Granville, Ohio 43023.
You'd better keep your driveshaft and cross member. It's the same length for 904 and manual transmissions. The 904 and 3spd use the same slip yoke but the 4spd uses a 727 yoke.
I have another cross member and drive shaft from my car I'm keeping. Thanks for the info though.
