Doug.S
1964 Dart More Door
So I have a 1964 Dodge Dart with /6 and A904 push button auto. Trans came out the car for a rebuild and I have been tearing down and cleaning the sub-assemblies for the rebuild. Trans ID is 2408002S which is a 1963 A904 HD and the production date or serial stamp is 0891693. When I got the thing on the bench I realized I don't have a filter attached to the valve body, I have a metal mesh screen. I understand that some cars around 1963-1964 had this set up with a filter in the cooler lines. I found that inline filter from fatsco, but that is not what I want to do. I want to know if anyone here has any knowledge of the conversion over to the two hole filter that screws to the bottom of the valve body? In the 1964 parts catalog under 21-117-0 TRANSMISSION OIL FILTER there is a NOTE: See Code 9-46-27 for tubes. Then it lists a filter part# B2466846 and gastket part# 2205202. I really want to know what that Code -46-27 is all about. Or has anyone out there already done this?
Thanks
Doug
Thanks
Doug
