ScamperTom
Supposed to be working
There are lots of threads on how to set up the kick down linkage properly, but my problem is at the trans.
I replaced the shift shaft/kickdown lever seal on a new used transmission. After reinstalling the lever, it now points forward, not sideways. Moreover, the lever on my old transmission had a significant amount of "spring" to it, whereas the new one just swings back and forth with no resistance. Here's a picture of the old transmission, with the position and arc of the lever on the new one in red.
Right now the kick down linkage won't function properly because the lever is too far forward. I'm confused: these levers only go on one way, right? It's almost as if the entire shaft swung 90 degrees. Am I missing something here? Did some transmissions have the kick down lever facing a different way?
