I see your not going with a cam now but when you eventually do I'd stick with something similar to comp xe262, engine masters did a build to a stock low compression long block with 4bbl, headers and that comp cam and made 282hp at like 5000rpm and made with stock 2bbl and cam with headers 170hp so you should be around 200hp show you how weak the stock cam is.
