ac swap with 5.7
Stone Runner
Active Member
Montana
I have a roller /6 72 duster w/o ac and planning on installing a 3g hemi. So I have clean slate to work with, not going after stock interior. I also have a 90 taurus with ac and fried tranny and a very good body (wife's old college car). Planning on using the taurus for a donor of sheet metal and anything else.
I am new to a/c, any good reading material out there?
Can I scab parts from the taurus and build a modified a/c system? I saw the post on the dakota swap.
Or is better to get a vintage air system? Would prefer not having the vents under the dash.
When I buy the salvage hemi what parts should I include with the motor?
Thank you for any input. Will post the project which ever way I go.
Get everything you can with the engine as far as wiring/pcm/bcm/dash harness/key/ignition switch etc etc. also make sure you get the accesories off that engine. As far as A/C try to get a Truck motor so you have room for the compressor.
