Which vents?
StanfieldNC
Stanfield, NC
Good morning!
In the 69 dart with ac/heat, set up like the photo below. Should the heat blow out of the front vents or inky the floor? I just had new ac parts installed and the A/C runs out of the front, but the heat is only coming out of defrost and floor. Thanks!
I don’t know why; my 65 is the same.
I’m no mechanical engineer but possibly it ciuld be changed to a more modern setup with the vacuum pods and linkages
FWIW heat onky systems are floor and defrost
I can’t remember if B, E or C bodies were the same or not
I'd imagine there'd be a way to bypass that to make heat come out of the AC vents. When pressing buttons, it will come out of those events for a microsecond.
