Defrost Vents - 3d Printed
tmj91
Member 10,000
I had some free time so I 3d modeled and then printed some defroster vents. I used the replacement defroster vents I just got in as a reference. Mine are on the left in each picture. I won't be near my car for a few weeks, so if anyone wants to print one out and test fit I'll gladly send the STL.
Mine are printed in ASA on a Bambulabs textured PEI sheet so it gives a very good replication of the original texture. ASA should be able to handle the UV and heat.
As a follow up, got these installed. Fit perfectly, and can even use the original nuts if you still have them. I will probably be updating them to have the little nubs on the end where the hose goes over to keep it on. The originals have them, but the reproduction I based my model on did not.
